i strat the dish water not going to the dishwasher ,I check the vavle work ok. what is bed.no power to the vavle but dish work whit out water model is JDB8901aws
Here are your parts includes a wiring diagram Replacement parts for JENN-AIR JDB8910AWS Dishwasher - Undercounter | AppliancePartsPros.com[COLOR="Blue"]no power to the vavle[/COLOR] I am assuming you checked it with a meter. Note that the float switch is inline with the valve. Check for power across the float switch or both the valve and float switch. If it has 120 volts when the unit should be filling the switch is open. Could be a bad switch OR Could be just that the float needs cleaning (stuck in the up position) If there is no 120 volts then probably the timer is shot or you have a broken wire. |
THIS FORUM IS DEAD!!!!!!! |
