I have a Frigidaire GLEB30T9FBA Double Oven. The lower unit will not heat up past 200 degrees. I have swapped the elements from the lower unit with the upper unit. The elements work fine in the upper unit. I ordered an EOC and installed it, there was no change in the lower unit. I ordered a Relay Board and changed it, there was no change in the lower unit. I checked the temperature probe and measured 1056 ohms at 70 degrees F. Is there anything else I can check?
