When the freezer is auto defrosting the water runs into the refrigerator or on the floor. I do not know how to access the drain hose to the condensation pan.:rolleyes:
The easy fix is to empty the unit, turn it off and leave teh doors open for 12hrs. If that isn't an option remove the back wall of the freezer (1/4 nuts) Beneath the evaporator is a catch. You'll find that it's iced up. use hot water to defrost. Once the hot water flows freely to the pan under the unit you're done.
