helpwanted
#1 Posted : Friday, January 29, 2010 10:48:24 AM(UTC)
helpwanted
the code on my electronic temp control is reading CE the manual says operational error and contact service technician. press alarm reset to stop audible alarm. The compressor continually runs. Ice cream in freezer is "too frozen"? I am not sure but I think it's something wrong with the temp control and the freezer does not work with that disconnected.
#2 Posted : Saturday, January 30, 2010 3:15:26 AM(UTC)
The following should help
http://frigidaireservicetips.com/pdfs/472_ElectronicControledFreezerServiceManual.pdf
Run the diagnostics on Page 20.
If nothing shows up, I would check the thermistor with a meter, 10,000 ohms at 77 degrees F (Page 20)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
Field Service Code Diagnostic- GE Washer (Washer Repair)
by S2sailorlis 12/16/2014 4:21:04 AM(UTC)
Service code 'nd'? (Washer Repair)
by mikejames 8/7/2011 9:44:43 PM(UTC)
