ayellis
#1 Posted : Wednesday, April 16, 2008 6:47:04 AM(UTC)
ayellis
my dryer is no longer heating. What could be the problem?
#2 Posted : Wednesday, April 16, 2008 3:03:13 PM(UTC)
The first thing I would do is check for 240V at the power outlet.
If there is nothing wrong then check the following parts for continuity:
1. The heating element (#17 on the break down diagram)
2. The thermal cut-off (#6 on the break down diagram)
3. The hi limit thermostat (#15 on the break down diagram)
4. The cycling thermostat (#19 on the break down diagram)
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
Any of these parts with an open circuit has to be replaced.
- The part number for the heating element is AP3109438
- The part number for the thermal cut-off (including the hi limit thermostat) is AP3094224
- The part number for the hi limit thermostat is AP2973862
- The part number for the cycling thermostat is AP3115922
Here are the break down diagrams for the Whirlpool dryer Model LE6800XSW0
