oil leak coming from what looks likes an oval metal cased gear box or transmision of some kind. Is it repairable and if so please explain and if not can you point me in the right direction for parts,prices and do it yourself repairs. Im self employed and work is slow any and advice is appreciated espescially cheapest yet most efficient fix appreciated. thank :confused: you
If the tranny is leaking oil, you probably have a bad transmission, the newer direct drive tranny's are pron to do this. Make sure the oil is from tranny and not the tub seal above the tranny.
