Cindy Townsend
#1 Posted : Thursday, January 28, 2010 3:46:03 AM(UTC)
Cindy Townsend
the freezer is working fine. it is not defrosting though build up in the freezer the referigerator part is not keeping items cold. I have replaced the defrost timer seemed to help for a couple of weeks now back to the same ole problem
#2 Posted : Thursday, January 28, 2010 5:05:55 AM(UTC)
Replacement parts for AMANA ARB2217CC Ref - Bottom Mounts | AppliancePartsPros.com
Sounds like the timer was not the problem.
Did you try forcing a defrost cycle before replacing the timer?
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Cindy (Washer Repair)
by cglover54 10/14/2011 11:18:28 AM(UTC)
cindyinlexington (Dryer Repair)
by cindyinlexington 10/3/2010 7:45:03 AM(UTC)
cindy (Washer Repair)
by cindy holliday 12/16/2009 5:15:57 AM(UTC)
