pabaholic
#1 Posted : Wednesday, January 27, 2010 5:56:16 PM(UTC)
pabaholic
Our dryer quit working today. The heating element is hot but no heat is getting to the clothes. The blower is working but there is an electrical smell. Thoughts?
#2 Posted : Thursday, January 28, 2010 1:26:47 AM(UTC)
Replacement parts for General Electric DDE5100SBLWW Electric dryer | AppliancePartsPros.com
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
