It will only run if you press very hard up against it. We have taken the panel off, and checked every wire to see it any had come loose, but they were all connected, and it still won't work on its own.
It's becoming frustarting because (nearly) everythingi n my home is breaking all at once.
Serial # is GA713314B
probably the float valve its inside the dish area usually on the right side up front under the dish rack see if its stuck see if its stuck
Sounds like the door switch, or the latch machanism
