I replaced just about everything on this beast two months ago and it has been working fine ever since until this morning when I noticed the ice bin was empty and there was a single ice cube wedged, sticking out of the tray. It popped right out but still no ice. The optics are clear, they flash twice, pause, flash twice, pause. I taped the flapper door closed, the slide switch is on. I unplugged the tray earlier and got the frozen cubes out so it is empty and ready to go. I unplugged the unit for about 20 seconds in hopes of resetting something to no avail. I've tried to jumper the maker and can't get any movement out of it. No matter what I do I cannot get a steady light on the optics. Bear in mind I put brand new optics in two months ago, I find it difficult to believe they are already bad..but I've been surprised before. Are there any other resets or restarts I can try? Any expert advice appreciated. It is a Kenmore elite (whirlpool) side by side with the ice bin in the door, about 5 years old.
Marshal :confused:
Originally Posted by: foobydoo  I replaced just about everything on this beast two months ago and it has been working fine ever since until this morning when I noticed the ice bin was empty and there was a single ice cube wedged, sticking out of the tray. It popped right out but still no ice. The optics are clear, they flash twice, pause, flash twice, pause. I taped the flapper door closed, the slide switch is on. I unplugged the tray earlier and got the frozen cubes out so it is empty and ready to go. I unplugged the unit for about 20 seconds in hopes of resetting something to no avail. I've tried to jumper the maker and can't get any movement out of it. No matter what I do I cannot get a steady light on the optics. Bear in mind I put brand new optics in two months ago, I find it difficult to believe they are already bad..but I've been surprised before. Are there any other resets or restarts I can try? Any expert advice appreciated. It is a Kenmore elite (whirlpool) side by side with the ice bin in the door, about 5 years old.
Marshal :confused: After about 12 hours of leaving it alone it finally started working again!
