The touch panel will not shut the oven off, although the touch panel appears to be working properly. The top burner element remains on and heats the oven to about 200F. Turning off the oven circuit breaker resets the oven and turns off the upper burner. No error messages are displayed on the control panel at any time. Other than this problem the oven seems to be working properly. Any suggestions would be appreciated.
Tom :confused:
