My maytag washer has a small problem. In the spin cycle it will fill very slowly. I just replaced the water hoses and clean the filters. When you first turn on the machine it will fill fine there is plenty of pressure. Both in hot and cold water. The machine will go thru a it regular cycle. When it reachs the rinse cycle the water will come in slow. I have check the cold water ony and hot too it does the same thing. It looks like the valve is not opening all the way.
Need help Sancortez
