I want to replace the outer door frame, as it is cracked and the handle has come loose. Part number 906336. Does the part come with installation instructions? I can't see how to remove it from looking at the door. There are 3 screws on the inside right of the door, but removing them does not free the outer frame. Does it snap in and out?:confused:
Yes, you were right. It snaps in and out. Hopefully this video clip will give you an idea. The APP part number for the outer door frame is AP3119844 Gene.
