jhart
#1 Posted : Friday, April 11, 2008 7:00:58 AM(UTC)
jhart
Had a repair guy come out and check this electric double oven. He said that I needed a new control panel. I bought one from your site and installed it, and got a new error reading " F5 E1 " The technicians manual found inside the oven said it was the latch motor or sister board. I have now replaced both of those with parts from your site (again) and am still getting the same error reading. What can I do now?
#2 Posted : Friday, April 11, 2008 2:24:09 PM(UTC)
What was the original problem?
jhart
#3 Posted : Sunday, April 13, 2008 1:11:36 PM(UTC)
jhart
the original problem was the oven just started beeping one day and then the display went blank and I got no response from the keypad except for the light. about 2 weeks later it just came back on (the display) and the oven worked. a couple days later, it went out again. i tried resetting by turning the power off to the oven for 30 min, but that didnt work either. i cant remember if there was an error code, but i think it might have been "f1"
#4 Posted : Tuesday, April 15, 2008 9:16:32 PM(UTC)
jhart,
The first and major failure suspect at this time is the control board.
There is also a small chance that the low voltage transformer is malfunctioning too.
- The part number for the control board is AP3595759
- The part number for the low voltage transformer is AP3968801
P.S. Did you perform all troubleshooting recommended in the tech sheets before you replaced these parts?
