OK, I've been on the boards and read as much as I can find. The problem appears to be that the dishwasher doesn't fill completely. I should be getting about 1.5 gallons in the fill cycle but seem to get less than that.
When I add extra water, it seems to run fine, and both upper and lower arms turn.
Here is what I have done so far:
-took off and checked both arms for obstructions -- nothing -checked the accumulator cover and sump for debris -- nothing -took off the inlet protector and checked the chopper and screen for debris/obstruction -- nothing - replaced the sump check valve -- no improvement - removed the pump assembly and checked the impeller for damage or obstruction -- nothing. Everything turns freely and looks fine. - checked resistance of the solenoid -- 986 ohms, which is in the range expected. - took off the fill valve and checked for obstruction -- a couple of small bits of debris. Nothing that looked big enough to impair flow. - checked water supply line for flow -- plenty.
So.... is there any other reason that there isn't enough water coming in? Should I just replace the fill valve? Comments/suggestions welcome!!
Here is a tech sheet for your unit which is actually a Whirlpool http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf[COLOR="Blue"] So.... is there any other reason that there isn't enough water coming in? [/COLOR] Could be something weird like a timer issue but it is unlikely. [COLOR="Blue"]Should I just replace the fill valve?[/COLOR] That is what I would do as you have done a thorough job of troubleshooting and it is at the top of the list as the cause. |
THIS FORUM IS DEAD!!!!!!! |
Thanks -- I'll give it a try.
Originally Posted by: cbprincipal  Thanks -- I'll give it a try. Denman, The new fill valve worked like a charm -- thanks!
