broker
#1 Posted : Saturday, January 23, 2010 9:55:04 PM(UTC)
broker
I need to replace the door latch on my
Kenmore Elite front loading washer. I
purchased the latch from Sears. It appears
to be held in place by 3 screws which are
accessed from the front of the washer but
I will have to get behind the front of the
washer or behind the rubber boot to get
the old one out and put the new one in.
There are 3 electrical connections that have
to be removed from the old latch and put
onto the new one. I assume that the front
panel of the washer has to be removed
unless there is a way to get behind the
rubber boot.
Please send me instructions to remove the
panel (or rubber boot if possible) and install
the new latch. Thank you.
Broker
ApplianceJunk
#2 Posted : Sunday, January 24, 2010 4:22:22 AM(UTC)
ApplianceJunk
I have always removed the top or more often removed the boot just by the door switch.
The boot should be held on by a wire and spring.
Door Latch Replacement - Connections (Dishwasher Repair)
by Riggs1955 2/1/2014 9:44:15 AM(UTC)
Oven door latch replacement on electric Maytag stove (Oven Repair (including Ranges and Cooktops))
by trav1944@yahoo.com 4/5/2011 5:41:36 PM(UTC)
Dryer Door Latch Replacement (Dryer Repair)
by Cowboys 12/27/2010 10:25:53 AM(UTC)
Door latch replacement (Dryer Repair)
by walkman1 5/6/2009 5:45:39 AM(UTC)
Whirlpool Duet - Door Latch Replacement (Washer Repair)
by zentmeyer 4/26/2009 7:16:08 AM(UTC)
Door Latch Replacement (Microwave Repair)
by rdsstubb 3/17/2008 11:55:18 AM(UTC)
