MUIRTER
#1 Posted : Wednesday, April 9, 2008 2:49:01 PM(UTC)
MUIRTER
When The Button Is Pushed To Start The Drier It Sounds Like It Is Ok But The Drum Does Not Turn. You Give It A Turn Manually And Yhen It Is Fine.
bambiblaster
#2 Posted : Wednesday, April 9, 2008 4:30:56 PM(UTC)
bambiblaster
The start windings in the motor are bad most likely you have a blocked vent and lint got into the dryer and choked the motor... New motor is needed and possibly the blower wheel as they are hard to get of on dryers with some age and must be cut off...
Start button turns on heater but drum does not turn (Dryer Repair)
by Guest 12/16/2021 7:42:16 AM(UTC)
Dryer Heats, but drum does not turn (Dryer Repair)
by tzmango 2/21/2019 1:47:43 PM(UTC)
Dryer turns on but drum does not turn (Dryer Repair)
by brandybear25 11/22/2014 8:43:48 AM(UTC)
dryer heats but drum does not turn when turned on (Dryer Repair)
by phylli5491@gmail.com 11/7/2012 10:05:38 AM(UTC)
Washer puts water in drum does not turn only hums and water does not drain (Washer Repair)
by vsquared 6/23/2012 7:09:22 PM(UTC)
Dryer Drum does not turn (Dryer Repair)
by javvy 7/25/2011 6:26:54 PM(UTC)
Drum Does Not Turn (Dryer Repair)
by Paulie K 10/19/2010 6:24:29 PM(UTC)
Dryer Heats...but drum does not turn inside (Dryer Repair)
by nextel8 8/22/2009 11:08:54 AM(UTC)
Motor running but drum does not turn (Dryer Repair)
by chaz24 7/23/2009 5:49:25 PM(UTC)
Drum does not turn as free (Washer Repair)
by fjohnson 6/21/2009 9:34:07 AM(UTC)
Dryer Drum Does Not Turn (Dryer Repair)
by Pike 12/17/2007 6:09:30 PM(UTC)
Light comes on, timer clicks, drum does not turn. (Dryer Repair)
by bradleyque 10/11/2007 11:43:27 AM(UTC)
