Dave Hahn
#1 Posted : Wednesday, April 9, 2008 1:20:30 PM(UTC)
Dave Hahn
Dear Sir:
The above mentioned dishwasher fills, washs (never stops washing) but do not move on to the next cycle. I have replaced the solid state control panel; however, the same problem still exists.
What is my problem?
#Thank You,
Dave
#2 Posted : Thursday, April 10, 2008 10:51:12 AM(UTC)
Hi Dave,
Which part did you replace: the control panel or the control board? How did you find which part to replace?
Dave Hahn
#3 Posted : Thursday, April 10, 2008 1:04:58 PM(UTC)
Dave Hahn
Hi Gene,
First Thank You so very much for your reply-it is greatly appreciated.
The new installed part number is Maytag 99002823. I determined this part number because the machine was not advancing to the next cycle (from wash to pump-out). Becuase it is a solidstate timer this was the logical step.
As I said-this did not solve the problem-the machine just continues to wash-on and on and on and on.
Is there a way to reset the electronic control board (iniitialize the system)?
Your help and/or assistance will be greatly appreciated.
#Thank You,
Dave Hahn
Telephone 605-279-2666
#4 Posted : Friday, April 11, 2008 10:40:02 AM(UTC)
Dave,
For how long time it was not advancing?
Your dishwasher has a temperature pauses a few times during a cycle while it's heating water, and if incoming water is too cold (manufacturer recommended at least 120°F) - it could take a pretty long time. The normal cycle could run for more then 100 minutes and it has nothing to do with the dishwasher.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
