lkajae
#1 Posted : Saturday, January 23, 2010 1:09:03 PM(UTC)
lkajae
My dryer has no heat on all but one setting,the automatic dry setting. it gets hot but then runs without stopping. How can I fix this please? thank you. Keith
appliGuy
#2 Posted : Saturday, January 23, 2010 8:22:36 PM(UTC)
appliGuy
There is a little cover on the front of the unit, on the lower left side. Pop that cover off and start it, let it run for a minute and let me know what you see. Do this in all of the cycles. (Time Dry and Automatic)
lkajae
#3 Posted : Sunday, January 24, 2010 11:50:24 AM(UTC)
lkajae
ok thanks. there is a glowing light like a glow plug that comes on then turns off on all settings but there is no flame. it lights some of the time but goes out soon after. thanks for your help. Keith
appliGuy
#4 Posted : Sunday, January 24, 2010 12:15:40 PM(UTC)
appliGuy
You have a bad set of coil kits. They are located on the gas valve and can be replaced without replacing the complete gas valve. They are black and come as a set. They are about 20 - 30 dollars.
This is assuming of course you have verified gas to the unit.
lkajae
#5 Posted : Monday, January 25, 2010 9:14:04 AM(UTC)
lkajae
ok thanks for your help. I will take it apart when I figure out how to get to the coils and replace them. again thanks for the help keith
