Refrigerator stopped making ice and dispensing water. It has now started making ice but it is still not dispensing ice or water.
I had same problem. I took off front water dispenser panel, which opens to switches that work off the ice and water dispenser arms. My water dispenser relay switch was supposed to be held in place by two thin pieces of plastic but both were broke and the switch was not being pressed by the water dispenser arm. I took two zip ties and secured the switch in the proper place and now the water dispenser works fine.
