When the cooking ends and that timer shuts off, the turntable continues to turn. It stops when the door is opened, and after leaving the door ajar for a few minutes, usually I'll hear a click and it'll be "safe" to close the door again. Sometimes I have to slightly open and close the door several times to get it to stop, though. What causes this and how can I fix it?
Most likely the problem is a bad smart board which has to be replaced. - The part number for the smart board is AP3994110 Gene.
