I need to replace the relay that opens and closes the ice exit door. I would appreciate it if you could help me disassemble the icemaker on the door. The refrigerator is a GE PSS27NGMA WW.
Thanks so much for the help
Originally Posted by: Palsco1  I need to replace the relay that opens and closes the ice exit door. I would appreciate it if you could help me disassemble the icemaker on the door. The refrigerator is a GE PSS27NGMA WW.
Thanks so much for the help I figured out how. Look on the front where the ice comes out, where the control panel is. On the control panel follow the front down, look right under the front of the control panel and you will see 2 holes about 2 inces apart. Cut a piece of coat hanger wire and press it into the holes just enough to release the clips. Panel pulls out from the front bottom and then there are 4 screws to take out and work your way inside. Be sure to disconnect power first.
