flutientn27
#1 Posted : Wednesday, January 20, 2010 2:08:12 PM(UTC)
flutientn27
Dryer worked fine yesterday/did a couple of loads of clothes and dried fine. Now blowing out cold air.. What could it be.. ? Thanks flutie
#2 Posted : Thursday, January 21, 2010 2:54:41 AM(UTC)
Replacement parts for MAGIC CHEF CYE3005AYW Dryer - Ele | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/maytag_library/docs/16027521.pdf
And a manual
http://www.servicematters.com/maytag_library/docs/16026315.pdf
Can be a number of things:
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 15 ohms approximately.
Thermostats, all should be 0 ohms.
After that there is the timer contacts and the motor's centrifugal switch.
