dlford
#1 Posted : Monday, January 18, 2010 2:43:46 PM(UTC)
dlford
The Heater Harness needs replacing, my question is, can you replace a single element heater with a dual element heater? I picked up a dual element heater, without knowing what element heater I had in the freezer. Or do I need to purchase a dual element heater.
Thanks,
Derrick
#2 Posted : Tuesday, January 19, 2010 3:28:00 AM(UTC)
Replacement parts for GSS23WGTA models | AppliancePartsPros.com
Take a look at Item 230 in Section 3, dual element heater.
Note that there are a number of different dual element heater kits depending on the unit.
[COLOR="Blue"]The Heater Harness needs replacing, my question is, can you replace a single element heater with a dual element heater?[/COLOR]
See above.
Not sure if the above will fix your "Heater Harness" problem.
Click on the parts picture and a new page will open showing you what comes in the kit.
[COLOR="Blue"]I picked up a dual element heater, without knowing what element heater I had in the freezer. Or do I need to purchase a dual element heater.[/COLOR]
I think there is a typo above as you say you bought a dual element and then ask do you have to purchase a dual element.
Or perhaps I am just interpreting it wrong.
