rokemo
#1 Posted : Monday, January 18, 2010 10:03:10 AM(UTC)
rokemo
I've seen posts regarding the defroster drain freezing issue for other models but not for a Kenmore refrigerator. For a Kenmore Coldspot model # 106-71182101 can anyone tell me if there is a specific repair kit for the drain freezing issue? Thanks.
#2 Posted : Monday, January 18, 2010 12:57:43 PM(UTC)
Your refrigerator made by Whirlpool and you can use any instructions or advices you found for Whirlpool top-mount refrigerators. There are no any special repair kits to solve such problem. The best you can do is keep the drain hose clean, especially at the bottom end.
luv2fix
#3 Posted : Monday, May 24, 2010 10:32:43 AM(UTC)
luv2fix
When I worked for Sears in another department I was aware of a repair kit that involved a wire that wrapped around the evaporator heater and reached a little into the drain to keep water from freezing and blocking the drain but I don't know the part number.
#4 Posted : Monday, May 24, 2010 2:33:06 PM(UTC)
It's never been made by a manufacturer and sold as a part. You can make it yourself.
Guest (4)
Defrost Drain Freezing (Refrigerator & Freezer Repair)
by reynolds1 1/3/2008 6:07:26 PM(UTC)
