The bottom agitator still moves during wash, but the top agitator no longer moves. I think I can use the Agitator repair kit for my Whirpool washer, but I have no clue how to disassemble the top of the agitator. Can someone lead me to a reference source? Thanks.
I beleive you remorve the top cap by unscrwing or pulling off. then you need to remove the softner cup by pulling up. You will see a bolt holding the 2 parts together. It may be that the dawgs are bad and need replaced.
Originally Posted by: jdman I beleive you remorve the top cap by unscrwing or pulling off. then you need to remove the softner cup by pulling up. You will see a bolt holding the 2 parts together. It may be that the dawgs are bad and need replaced. Thanks, I'll give it a try!
