I have a loud squeeling noise that sounds loudest at the motor. Sounds like a bearing. was woundering if there was any other parts in that area that could cause the noise to travel through the motor.:confused:
Originally Posted by: JD40  I have a loud squeeling noise that sounds loudest at the motor. Sounds like a bearing. was woundering if there was any other parts in that area that could cause the noise to travel through the motor.:confused: I have model FDB636GFS1. I had a sudden squeeling in the motor area that turned out to be a cracked plastic part of the pump assembly which fits on the splined shaft of the motor, might want to check the impeller to see if it is turning when you hold the motor still. Stewie
