I have the above dishwasher but it has a problem. It's in a cricket club pavilion & hasn't been used since September, but it worked fine then. It's been left unplugged over the winter but the water wasn't turned off. However, I have just tried to use it & it starts fine, & I can select which program I want, & the estimated time displays OK, but all I can hear is a pumping sound. The program continues, the counter counts down, & it even releases the tablet from the compartment, However, no water is being taken into the machine - the contents are completely dry. The countdown timer counts down to 1 but doesn't finish. I have taken the water feed pipe off & checked that water comes out of the end & it does. Any advise as to which part I should be looking at & how I get to it would be greatly appreciated. Thank you in advance.
Most likely the problem is a bad control module. Unfortunately I'm not able to provide more accurate advise due to this is UK model and we do not have any access to information for non American models.
