Christiaan
#1 Posted : Sunday, January 17, 2010 1:31:35 AM(UTC)
Christiaan
My whirlpool 1dp252 dishwaser doesn't warm its water and im not sure where to find the termostat.....
#2 Posted : Monday, January 18, 2010 1:46:46 AM(UTC)
Cannot find any info using the given model number, please check it.
First remove power from the unit
Then one wire from the heating element and check it with a meter, usually around 20 ohms.
Next there is often a hi-limit thermostat wired in line with the heater and attached to the bottom of the tub. Remove one wire from it and check it with a meter, should be 0 ohms
