pete washo
#1 Posted : Wednesday, April 2, 2008 6:21:03 AM(UTC)
pete washo
I keep cleaning the ribbon plug connecting the console to the electronic control. This seems to correct the problem of blinking lights and washer not working for about 4to6 washings. Then the conection seems to fail again. Is there a way to clean it without buying a new console? I used electric contact spray cleaner. Thanks Pete
#2 Posted : Wednesday, April 2, 2008 9:04:20 PM(UTC)
Hi Pete,
I understand you don't like to spend money but, as I recommended earlier, the only solution to solve this problem is to replace the console (aka control panel).
- The part number for the console is AP3097136
