pnowacki
#1 Posted : Friday, January 15, 2010 6:38:18 PM(UTC)
pnowacki
I first changed belt, then snubber, brake and stator. Sometimes spinning cycle runs faster then stops all together. I now have a loud nosie fearing transmission maybe culprit. Am I correct?:( I noticed lower plastic gear wont push brake in when I turn it by hand?
sidfink43
#2 Posted : Sunday, January 17, 2010 3:41:48 PM(UTC)
sidfink43
It may be the transmission, but try replacing this part and see if that does not fix your spin problems.
Part number: AP4009132
Water is left in washer, door is locked cannot open, does not drain, clothes still wet (Washer Repair)
by Guest 12/4/2022 11:52:36 AM(UTC)
kenmore he2 clothes still wet (Washer Repair)
by ldenorio 2/9/2020 2:55:08 PM(UTC)
Crosley Washer (Whirlpool) not spinning fast enough, clothes still wet (Washer Repair)
by Cajun Girl 12/5/2018 12:12:13 PM(UTC)
clothes still wet after cycle spin (Washer Repair)
by biho 12/25/2015 8:35:07 PM(UTC)
Spins but clothes still wet (Washer Repair)
by tom rosser 8/11/2014 10:59:53 AM(UTC)
Maytag top load - drains & spins but clothes still wet (Washer Repair)
by Liz459 3/24/2013 4:26:14 PM(UTC)
clothes still wet after 1st spin cycle but dry after 2nd spin cycle (Washer Repair)
by sscaduto 11/10/2012 1:28:37 PM(UTC)
Clothes still wet after spin cycle (Washer Repair)
by gbdad10 3/31/2012 3:35:25 PM(UTC)
Clothes still wet after spin (Washer Repair)
by Ranger25 7/24/2011 2:43:22 PM(UTC)
Clothes still wet (Washer Repair)
by davjulcos 3/10/2011 8:06:42 AM(UTC)
Maytag stackable SG7800 clothes still wet at end (Washer Repair)
by smr277 10/9/2010 10:12:31 PM(UTC)
Clothes still WET after final spin (Washer Repair)
by HandyHubby1963 7/2/2010 7:00:52 AM(UTC)
by Rheinking 4/30/2010 11:19:45 AM(UTC)
Neptune washer spins and pump working but clothes still wet (Washer Repair)
by lanehi 10/25/2009 4:07:25 AM(UTC)
by PTJT5 9/27/2009 8:55:52 AM(UTC)
