musicmanern
#1 Posted : Monday, March 31, 2008 10:08:31 PM(UTC)
musicmanern
Is there a better way to check the temperature control selector switch when it is out of the circuit. I suspect the switch is bad, but I get irratic readings when I make continuity checks with a DVM. I had to replace the thermal switch, but the dryer still won't start.
musicmanern
#2 Posted : Thursday, April 3, 2008 1:14:17 PM(UTC)
musicmanern
I replaced the temperature selector switch and when I tried to start the dryer, it buzzed a couple of seconds then quit. I did smell something burning. I checked the resistors on the plug (two violet wires) and the're ok. I'm beginning to think the motor might be the problem. Any other suggestions before I go to all the trouble to check the motor windings?
Temperature Selector Switch broken (Dryer Repair)
by bobmike 5/9/2013 11:47:17 AM(UTC)
Need help determining if a Temperature Selector Switch is Faulty??? (Dryer Repair)
by akarrera 2/5/2010 10:14:43 AM(UTC)
