Gene,
I jsut wanted to publicly thank you for your help and advice last week when I had questions regarding my Roper washing machine.
I received my parts today (motor coupling & clutch assembly) and was able to install them per your instructions.
So far so good. The washer worked through a complete empty cycle, and I'm now doing a test run with some linens to make sure it's all figured out.
Thank you again for your help! K.D.:)
There is no doubt Gene is the best of the best!!!!
Thank you to you as well Gabe. I was kinda confused as to HOW to get that clutch off. Your help was greatly appreciated. :) K.D.
