Please help my oven started a F2 so I reset it. It broil fine however will not heat properly set at 350 really is 200 so I increased temp now it flashes F2 more frequently. Please help
On most GE's an F2 error is an over-temp problem. This is probably the temperature sensor. The oven thinks it is hotter than it actually is. Here is a good link http://www.applianceaid.com/elecrange.htmlCheck out 7, 8, 20 and 21. Note this is a positive device. The resistance rises with temperaure so a dirty/loose/defective connection will also give a false high temp reading. |
THIS FORUM IS DEAD!!!!!!! |
