I found a leak around the screws that connect the inner and outer tub. I tried to tightened the screws but it still leaks, more when it is in rinse cycle. I think it is the tub seal:confused: . How much is this part? and also how hard of a job is this? I'm pretty good with tools. any help would be apreciated.
thanks
Did u get an anwer to your question about the seal? Mine is leaking and im trying to figure out how to fix it.
