Joe Grod
#1 Posted : Thursday, January 14, 2010 11:02:01 AM(UTC)
Joe Grod
The original soap dispenser on the Whirlpool Dishwasher GU1500 series, which had an addtional electrical lead for the rinse aid dispenser was replaced with a dispenser that only requires one lead.
What do I do with the second lead which appears to be no longer necessary?
#2 Posted : Thursday, January 14, 2010 4:18:36 PM(UTC)
Joe,
What is the part number for the dispenser in question?
Whirlpool has redesigned this part and changed the part number, but there are still two terminals for the solenoid and it requires two wires to be connected.
UserPostedImage
The rinse aid sensor (#11 on the diagram) is a separate part and has to be removed from the old dispenser or ordered separate.
UserPostedImage
Joe Grod
#3 Posted : Monday, January 18, 2010 8:07:46 AM(UTC)
Joe Grod
Gene,
Thanks for your response. The old "dispenser assembly" #8270034 (which you pictured) had a provision for the "sensor, rinse aid" #8533381 (also pictured).
The new "dispenser assembly" #8558129 does not have any provisions for the rinse aid sensor, thus leaving a two wire lead hanging.
What to do with the extra lead is the question.
Thank you
Joe
#4 Posted : Tuesday, January 19, 2010 1:51:32 AM(UTC)
Just tape it up and tuck it somewhere out of the way.
The have stopped using the rinse aid level sensing, probably was causing more problems than it was worth.
Whirlpool Dishwasher soap dispenser door (Dishwasher Repair)
by mocruzr 5/4/2011 12:14:57 PM(UTC)
Whirlpool dishwasher soap dispenser spring problem (Dishwasher Repair)
by remoandiris 2/15/2011 5:06:05 AM(UTC)
Whirlpool Dishwasher Soap Dispenser Won't Open During Cycle (Dishwasher Repair)
by Dr_Zoidberg57 9/1/2010 11:22:54 AM(UTC)
