All of the controls on this model are run by a key pad on the front of the dishwasher. When working normally the option selected will have a red light illuminate above the button pushed and when start is pressed the dishwasher will run.
Now when I push a button the key pad several lights light up all at once and when the start button is pushed the dishwasher will not start. I suspect that I need to replace the key pad control panel but I can't find one online.
Any ideas would be appreciated.
Thank You,
I manage to fix it (probably short term) by turning off the power to the dishwasher at the breaker, waiting 20 seconds and turning the power back on again.
Cheers,
