bajaeddie
#1 Posted : Wednesday, January 13, 2010 4:40:13 PM(UTC)
bajaeddie
Evaporator fan area keeps freezing and stops the fan.
Which stops the cooling process.
Any Ideas?
Thanks ,Eddie
John @ Fischers
#2 Posted : Wednesday, January 13, 2010 4:53:51 PM(UTC)
John @ Fischers
Defrost timer, Defrost thermostat, defrost heater.
Defrost timer will defrost coil every 8-10 hours of operation.
Remove the middle and lower panels, 1/4 nut driver will fit the screws.
Defrost thermostat is attached to coil. Unplug refrigerator, unplug 6 pin connector that have the 2 wires in it going to defrost thermostat and get a test meter and ohm out the 2 wires going to the bulb(Defrost thermostat), with no ice on the coil should get around 150-180 Resistance Ohms.
If less than this, replace bulb. Also, ohm out the defrost heater while your in there. Should get 0 ohms across the terminals.
Post back results
Freezer keeps freezing up in the summer (Refrigerator & Freezer Repair)
by cmberges 8/20/2013 9:36:06 AM(UTC)
Maytag fridge above freezer keeps freezing up (Refrigerator & Freezer Repair)
by thecanderson 8/22/2011 12:01:02 PM(UTC)
Freezer keeps freezing up on me (Refrigerator & Freezer Repair)
by Lmalex 7/12/2010 11:05:47 AM(UTC)
