I have a front loading washer, Inside the drum there are three, what I call three raised "plastic Spines" with small holes in them That are evenly spaced on the drum. I think a coin somehow got trapped inside one of them. I can here it moving front to back when I turn the drum. Is there any way of removing this "spine" from the inside of the drum? Are there clips that can be squeezed? Thanks for any ideas.
its been a while but isn't there 2 t-20 torq screws that hold those "baffles"? Then I think you just give a little slap toward you. I could be thinking of the older Neptunes, but its worth a look.
Thanks, I didn't see anything like that from the inside, but I'll look a little closer. I'm hoping they can be removed from the inside of the drum.
