Ice maker stopped. I have 120vac @ test points N&L. Shorted points T&H which caused motor to rotate and tray to fill. What now?
Sounds like the ice maker thermostat is the culprit. I would recommend to replace the whole ice maker because something else can be bad as well, and the rate of successful ice makers repair is pretty low. - The ice maker only (without harness, front cover & arms) Part number: AP4360346
You have to use the harness, cover and arm from the old ice maker. Gene.
If you left the jumper in and it still didn't work, you may have a bad connection to the mold heater= new icemaker time. Also, Make sure your freezer temperature is less than 15 degrees.
