colsen
#1 Posted : Sunday, March 30, 2008 6:31:09 PM(UTC)
colsen
I have a Kenmore gas dryer which has worked fine for many years. Recently it stopped drying. I removed the front panel and observed the burner. From a cold start it works fine - igniter glows, gas fires and runs for a few minutes. When gas cuts off the first time it will not restart - igniter glows then stops but no gas - this repeats every few minutes. Is this somehow related to the different funtion of the two soleniods?
fixtec90
#2 Posted : Monday, March 31, 2008 6:37:50 AM(UTC)
fixtec90
Yes it does relate to the coils (soleniods) The primary allows juice to the ignitor and the secondary allows gas to flow. Replace both.
