AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Spin and pump cycles stop and start, washer won't drain
After the wash cycle my washer spins and drains for 2-3 seconds then stops. It continues to do this several times before reaching the next cycle leaving the tub full. Then the dial moves by itself to the next settings (permanent press, delicate, etc.) and repeats the 2-3 second pattern at each drain cycle. I checked for clogs ( I didn't take the pump apart) but found nothing. Any idea how to solve this?
Washer Repair
