sherryh
#1 Posted : Sunday, March 30, 2008 2:43:10 PM(UTC)
sherryh
I recently moved. My washing machine was moved by movers. It works fine but started leaking - when checking it out I found the basket inside has a lot of "give" it moves more than an inch. It still agitates and spins but it leaks. I think when it spins it spews the water over the side. Does this make sense? Is this an adjustment I should be able to fix myself or do I need professional assistance? Thank you!
#2 Posted : Monday, March 31, 2008 12:26:40 PM(UTC)
The first thing I would do is remove the washer cabinet and pinpoint the leak.
Post your findings and we'll proceed further.
Washing Machine leaking - spin basket out of balance? (Washer Repair)
by sherryh 3/30/2008 3:31:34 PM(UTC)
