rogerskoler
#1 Posted : Sunday, March 30, 2008 12:10:50 PM(UTC)
rogerskoler
Thanks for taking the time to read my question.
I received my Kenmore microwave as a Christmas gift in 2006. My light has gone out of it inside. It's a table-top model. I tried to figure out where the light bulb is to replace it but I could not figure it out so I called Sears. They said since I didn't purchase a extended warranty that they can't help me or either I pay over 100.00 for service. This is a microwave...a small microwave that it would be crazy to pay for a service call when I could get another microwave at probably the same cost.
I just want to replace a simple light bulb. Nothing in the manual talks about this at all. It's a maintenance issue not something that should be covered under a warranty. Geez.
Is the only way I can replace is go thru Sears and pay an arm and a leg. I'd really rather do it myself. It's not my fault they made it difficult for owners to do and want to charge. What a racket.
I looked on the back of the unit and evidently I'd need specail tools to remove casing. Why o why did Sears/Kenmore make a microwave where it's a major issue to replace a simple bulb and why is the heck did it go out in just over a year? This is crazy.
Any help would be appreciated. Thanks.
#2 Posted : Monday, March 31, 2008 11:51:17 AM(UTC)
Originally Posted by: rogerskoler Go to Quoted Post
...I looked on the back of the unit and evidently I'd need specail tools to remove casing. Why o why did Sears/Kenmore make a microwave where it's a major issue to replace a simple bulb and why is the heck did it go out in just over a year? This is crazy...
Yes, you have to remove the casing to access the lamp and probably you'd need a special tools to do it. This is a way all counter-top microwaves made and it's done for consumers protection.
If you are still willing to do it, I would recommend to remove the old lamp and take to any hardware or electronic supply store to match it up.
rogerskoler
#3 Posted : Monday, March 31, 2008 12:32:48 PM(UTC)
rogerskoler
Thanks Gene. Come to find out after calling Sears again is that the part is 59.00. I don't have the special tool and I'm not willing to pay for someone to install a 59.00 halogen bulb. The darned thing should not have gone out when unit is just over 1 year. Who is going to pay that much money to fix a bulb every year or so on a microwave? Not me. I'll cook in the dark.
Thanks for your response.
I highly recommend that no one ever buys a Kenmore microwave.:mad:
Carl.
#4 Posted : Saturday, January 2, 2010 11:15:34 AM(UTC)
Carl.
I found a light bulb for my Kenmore microwave for around $13 after shipping.
Then purchased a "SE 33 pc. Security Bit Set" for $5.40 at Amazon.com
Replacing the bulb required removing 2 phillips head screws and 4 security screws from the outer case. Pulling back on the case then lift up to lift it off. The bulb was held in by a bent tab. Just pry the tab straight and lift out the bulb.
