The ice machine is making ice fine but in never stops making it. i believe that whatever tells the ice machine that the bin is full must not be working. What part would that be? Could it be multiple parts?
I am not an expeert but i beleive there is a bin full sensor on the right side of the bin. It is in a white tube and when the sensor gets cold, because the ice reachs it, it turns off the ice making. If the sensor is not working the machine will continue to make ice and not stop.
