The display board on my jenn air jjw8530aaw range/oven does not light up. all the controls work properly but nothing is displayed. all the connections look to be secured behind the panel. Any ideas
Same problem with out two built-ins. In fact at night there is just a little residule light comint from the LED window. Heard a couple years ago that it's a $400+ fix. Was hoping someone with Jennair experience might step up an give us an idea if this fix is doable for the do-it-yourself-er
roserfd & james can you both post your model numbers please
