Recently the dryer's heating element broke and blue a fuse. I replaced the fuse and the heating element and put it back together. Now what happens is that the heating element comes on but does not go out and ignite the gas. There are basically a pink and white wire that goes together and connected to the assembly to the right of the air duct. The black goes to the other terminal off of the air duck. Everything seems to look fine but no gas ignition. I don't smell any gas at all. It is turned on during this test.
Originally Posted by: RrBb ...the heating element comes on but does not go out and ignite the gas... Sounds like the problem is a bad heat detector aka a flame sensor (#552 on the diagram). - The heat detector Part number: AP2042635
Thanks Gene for the information. I'll be putting in a new one on Sunday. Rodney
Thanks Gene. I was able to replace the part that you had identified and we now can was and dry our clothes at home. Thanks again. RB Originally Posted by: RrBb Thanks Gene for the information. I'll be putting in a new one on Sunday. Rodney
I'm glad you were able to fix it.
