Hutton
#1 Posted : Monday, January 11, 2010 6:16:06 AM(UTC)
Hutton
Ordered Jenn-Air WW30430B part from Applicance Parts Pros and installed SWTCH-MEMB 71001873 because the previous membrane had a defective upper oven touch control. Simple enough, install by plugging in and I get nothing? Now we have no upper or lower oven. Clock flashes but cannot set it either.
Suggestions? Thanks, Hutton
#2 Posted : Monday, January 11, 2010 3:27:55 PM(UTC)
Hi Hutton,
You may want to take it apart again and make sure the membrane switch ribbon cable is firmly plugged into the control board.
If it would not help, then inspect the tracks in the ribbon cable for haircracks using a magnifying glass. Post the results.
Bad switch membrane 8272702 (Oven Repair (including Ranges and Cooktops))
by Fko 10/4/2016 6:56:05 AM(UTC)
Kitchenaid Hood Range How to install switch membrane Part #W10370009 (Oven Repair (including Ranges and Cooktops))
by ravisaini 2/11/2013 4:22:41 PM(UTC)
Replacing Electronic push-button Switch Membrane (Dishwasher Repair)
by wcampbell 6/6/2012 10:03:56 AM(UTC)
Testing Switch Membrane (Oven Repair (including Ranges and Cooktops))
by Philipones 4/29/2011 2:10:07 PM(UTC)
switch membrane R/R (Microwave Repair)
by westydog 1/19/2011 10:25:01 AM(UTC)
by Hutton 1/11/2010 6:17:37 AM(UTC)
Loss of Switch Membrane Touch Contols (Oven Repair (including Ranges and Cooktops))
by virdean 9/5/2008 11:36:03 AM(UTC)
Jenn-Air switch membrane (Oven Repair (including Ranges and Cooktops))
by roberts3a 3/17/2008 5:21:33 PM(UTC)
