I have a Frigidaire range at a lake house 450 miles away. Not sure about the model # of the range, but the EOC # is 316418204. The power was disrupted to the unit and it came on and off for 2 days. panel dead. A friend is troubleshooting the EOC and says the transformer is toasted. He needs the output voltage to replace it. Also, if you know an outlet that carries these transformers that would also be appreciated. thanks
Rank: Administration
Your local electric supply may carry it. As for the output voltage... Unfortunately, manufacturers don't usually publish specifics on EOC components. They want you to replace the whole board. The old transformer doesn't say anything?
