gnaburn
#1 Posted : Sunday, January 10, 2010 7:42:07 AM(UTC)
gnaburn
I have a whirlpool imperial series for a while it has made a grinding noise when washing. Now it fills with water then dose nothing but hum, but it will still drain. Any thoughts?
#2 Posted : Monday, January 11, 2010 12:00:09 AM(UTC)
Replacement parts for WHIRLPOOL DUL300XTLQ3 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
You will have to open up the pump and see what has happened.
Could be that something has jammed in the impeller but mat also be that the pump is toast.
